IrishG60
Brakes
They dont work anymore?
Seriously.... If you hear them grinding - metal against metal, get them changed asap. You can look through the alloy wheels to see the pads.
Erm, metal on metal is too late is you've probably just junked the disks as well.
Best bet is definitely to take a look - there's 3mm or so backing plate and the rest is pad. There's usually around 10-12mm of pad when they're new. When you've got none left, replace the pads.
If the disk is getting very corroded and/or you've got a big lip around the edge, then it's probably time to replace the disks as well.
Bear in mind that the rear wheel bearings are pressed into the brake disks, so you'll also need new bearings with the disks.
