KADVR6 0 Posted May 21, 2008 i have had a quick search, but can peeps with a vr6 that kept on stalling tell me how they stopped theres stalling?? the car in question is my brothers, we have changed plugs/leads/lambda sensor so far. as these are fairly cheap to replace. i cant swap ECU/MAF over as mine are different to he's. :( the car will stall for no reason at all, there is no pattern as to why it will stall also :? there appears to be no loose/broken hoses in the engine bay either any info/tips are very much appreciated. karl + lee Quote Share this post Link to post Share on other sites
peanut 0 Posted May 21, 2008 Have you changed/cleaned the isv? Quote Share this post Link to post Share on other sites
KipVR 1 Posted May 21, 2008 Reminds me of the days when mine was cutting out for no apparent reason a few years ago when I went round corners quickly :nono: , it turned out my keys were swinging turning the ignition off! Other reasons mine has been stalling over the years are Cam sensor breaking down fuel pump on its way out Immobilizer/never really found out. Quote Share this post Link to post Share on other sites
diggerbucket 0 Posted May 21, 2008 Mine has twice gone down the stalling route, first time it was the blue temp sensor on front of the engine, then it was the MAF. The MAF was constant stalling, the blue temp sensor was totally random and would also sometimes make it hard to take the throttle. Quote Share this post Link to post Share on other sites
KADVR6 0 Posted May 22, 2008 oh yeh sorry forgot to mention that the ISV has been cleaned. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted May 22, 2008 Did you check the engine for error codes? Quote Share this post Link to post Share on other sites
