Tedb 0 Posted May 28, 2008 Each time I change my Air Filter it is contanimanated with oil, just on the top of the filter in the centre, seems to be coming from the Fuel metering system, anyone know why this happens? Cheers Guys Quote Share this post Link to post Share on other sites
Dec 1 Posted May 28, 2008 Most likely cause is the crank-case breather pipe, which runs from the front of the block to the top of the airbox. That tends to carry a bit of oil into the air intake pipework. Quote Share this post Link to post Share on other sites
Tedb 0 Posted May 28, 2008 Cheers for that, I'll give the pipe a good cleanout and check it again in a few weeks to see if it's the same. Thanks Quote Share this post Link to post Share on other sites
barryarginnraddo 0 Posted May 29, 2008 mine does this too, maybe its common ? Quote Share this post Link to post Share on other sites
mattcorradowirral 0 Posted November 3, 2008 mine does this aswell as i found out 2nite it blow all the oil out of what seems to be that pipe that goes under the air fliter wich connects to a lil sencor and a vave and some oil has enterd the air in take because the spark plugs were coverd in oil any ideas what it could be would be off help.cheers.any help at all would be great full Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 3, 2008 mattcorrado, oil on the filter / intake system has already been explained above. It's the positive pressure crankcase breather system and is designed to decrease pressure buildup below the pistons. Quote Share this post Link to post Share on other sites
mattcorradowirral 0 Posted November 3, 2008 ah ok i see so would that mean its had too much pressure and that y it blow the pipe off. Quote Share this post Link to post Share on other sites
