mbaker8v
ATE Power Disks
Has anyone used ATE power disks? I need to replace the brembo Max disks I have on the front of my C as the yare down to minimum thickness after only 15,000 miles ( The Pagid fast road pads still have about 5mm hickness elft though, and they were fitted at the same time as the disks. Not looking to fit anyhting expensive as the car will be for sale as soon as my S3 company car arrives.
Any other suggestions? Had Zimmerman before and they warped... Brembo max are pretty cack, what else? Probably going to use EBC Greenstuff pads??
Cheers,
Mark
standard brembo discs from gsf seem to fair pretty well, look clean and simple as well!
Yep, GSF are stopping selling the Brembo kit as they are getting so many returns - I would take them back especially if you have them on the same reciept as the pads!
VAG discs all the way, properly balanced and last ages - G60 ones are £21 each (+vat) from TPS so as cheap as anything else out there!
If you're going to be selling it soon, just stick the normal Pagid pads or VAG pads on... they're 1/2 the price of the Greenstuffs!
