Adz The Rat 0 Posted June 11, 2008 Roughly how long does it take to swap inlet manifolds on a VR6?? Buying a spare one off Mis VW on here so I can get it polished up. My mate will fit it for me but has never done one on a VR before so wondering how long will take him....... Did a search but couldnt find anythin so sorry if this has been covered before Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted June 11, 2008 Wanting to give this a go too. You can do it yourself if you can hold a spanner. All engine plastics,pipes off, leads and plugs. Take throttle body off and ISV - May have missed something off that list. Shouldnt take more than an hour. Quote Share this post Link to post Share on other sites
Taggart 0 Posted June 11, 2008 The only pain is the bolts at the bottom of the lower manifold, they're a bugger to get to when you've got fat hands like me! Quote Share this post Link to post Share on other sites
VR6 0 Posted June 11, 2008 You need a skinny assistant. Quote Share this post Link to post Share on other sites
Adz The Rat 0 Posted June 11, 2008 The only pain is the bolts at the bottom of the lower manifold, they're a bugger to get to when you've got fat hands like me! It will be up on a 2 post ramp, will that help?? Quote Share this post Link to post Share on other sites
Taggart 0 Posted June 11, 2008 Nah, best attacking it from top. It's easy to do, just a bit fiddly. Quote Share this post Link to post Share on other sites
Adz The Rat 0 Posted June 11, 2008 Thanx people!! Will post pics when its done Quote Share this post Link to post Share on other sites
diggerbucket 0 Posted June 11, 2008 Doesn't take long at all, couple of hours for your first time maybe. And yeah those bolts are a pain! Quote Share this post Link to post Share on other sites
TimDoc 0 Posted June 12, 2008 make sure u get some new gaskets, as the older ones tend to come off in pieces! £14 for the set from VW main dealer, also when doing ya polishing/grinding, make sure you seal up all the holes in the inlet manifold or you will have to wash all the stuff out from the inside. Tim Quote Share this post Link to post Share on other sites
KADVR6 0 Posted June 13, 2008 when i had to take mine of for the red-tops, i just undid the front engine mount, then jacked up the engine it made it sooo much easier to get to the bolts. Quote Share this post Link to post Share on other sites
