Cnut
Vag-com results
Hi, I have just been playing around with vag-com and these are the results i got:
VAG-COM Version: Release 409.1-S
Chassis Type: 50 - VW Corrado
Scan: 01,02,03,08,15,25
Address 01: Engine
Controller: 021 906 258 CP
Component: MOTOR 2,8L 6-Zyl.
Coding: PMC 1 HS
Shop #: 0261203565
3 Faults Found:
00525 - Oxygen Sensor (G39)
03-10 - No Signal - Intermittent
00553 - Mass Air Flow Sensor (G70)
29-10 - Short to Ground - Intermittent
00513 - Engine Speed Sensor (G28)
03-00 - No Signal
Readiness: N/A
Address 03: ABS Brakes
Controller:
Note: Excessive Comm Errors
The engine was off but ignition on.
I take it that means I have a duff lambda probe and MAF? I'm not too sure what the engine speed sensor is though?
Cheers
Phil
Yes to both dodgy MAF and lambda but I would clear the codes, drive the car around and then re VAG-COM it to see if they are still there.
The engine speed one is easy, if the sensor is broken the car wont start but due to the early software issues it will display the sensor as failed when the engine is not running. Or in other words, the engine speed sensor fault is ok.
I cleared them, went for a long drive and rescanned and it's not displaying any fault codes now apart from the abs error. I think the maf error was caused by me unplugging the sensor whilst the engine was running yesterday. I'm not too sure about the lambda one though, its probably best i rescan again when the engine is stone cold.
If there is an error at any point whilst the car is running it is logged by the ECU, drive it for a week and have another go to see what comes up.
