jedi-knight83 0 Posted December 9, 2003 Quote so it's really just a case of taking the big connecting plug off, trying to find any dodgy contacts and putting it back that sound great :shock: :? :? :shock: where is that. sorry Quote Share this post Link to post Share on other sites
dr_mat 0 Posted December 9, 2003 erm.. dunno exactly.. Quote Share this post Link to post Share on other sites
stevemac 0 Posted December 9, 2003 ABS pump is just underneath the coolant expansion tank. It has a few brakepipes attatched to it. (that's where it is on my G60) Quote Share this post Link to post Share on other sites
jedi-knight83 0 Posted December 9, 2003 and i presume there is a plug there for all the connectors? Quote Share this post Link to post Share on other sites
stevemac 0 Posted December 9, 2003 Multi-pin connectors on Teves 02 ABS 35-pin connector for ABS Control Module (J104). 7-pin connector for valve block. Quote Share this post Link to post Share on other sites
Guest Posted December 9, 2003 vr6corrado said: The ABS light has never worked on my C but I think the ABS is working because the pedal 'pulses' just after i switch it on. Hopefully it's just the bulb? Anyone know how to get to it? just use a flat blade screw driver, and gently lever it out the box that the light lives in, then use the same screw driver to take this box apart, taking the box apart was a bit tight. Then you'll see the ickle bulb inside. Thera Quote Share this post Link to post Share on other sites
