G60SC_Stoney
CAT shield
now ive lowered my VR6 a bit, the CAT shield under the car has come loose and is knocking on the ground. DOH! now i know the easy thing to do is to go and get it welded back on there properly, BUT do i actually need it? i mean i could just go over another speedbump and take it off again? what do you guys do with stainless exhausts ?
am sure i've heard people say on here that you can just cut it off, but watch out if you park on long dry grass as it can burn from the heat
Yeah they fitted them cos cars kept setting fire to things underneath (and then the car) when parked up after a run.
Also be careful if you do remove it that the cat itself doesn't hit speed bumps, they aren't cheap......
hehe, well quick update, it fell off as i was driving to the garage this morining to take it off! its now sitting in the boot of my car! :lol:
mine is making a noise, keep meaning to get under car and have a look, am sure i bottomed out on some grassy bank earlier and the cat shield was to blame
