Martyn_McG 0 Posted July 14, 2008 i have a squeak comming from around the aux drive belt area and i have decided its the tensioner wheel bearing from other posts i have read, i also got the bearing needed to replace it from the knowledge base article, but my question is before i start replacing it can anybody confirm if when i put it back together i will have to set the tension or is it none adjustable? i ask because i dont want to drive round in fear that its going to be to tight and snap or loose and fall off!! Quote Share this post Link to post Share on other sites
paul20v 0 Posted July 14, 2008 hi its self tensioning so no fears there. Quote Share this post Link to post Share on other sites
Martyn_McG 0 Posted July 14, 2008 many thanks!!! better to clear these things up before i start pulling things apart and realise i cant finish the job, then i normaly :censored: :bad-words: :censored: :mad2: with a spanner :D Quote Share this post Link to post Share on other sites
paul20v 0 Posted July 15, 2008 thats human nature no problem any time :D Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 15, 2008 Yep, you just need an M8x80 bolt to de-tension Quote Share this post Link to post Share on other sites
