STORM 2
wiring assistance required - instrument cluster
Hi,
any electrical geniuses out there able to help on this one?
I'm trying to track the gearbox speed sensor (VSS- G2) wiring.
From the plug terminal on the actual sensor a wire goes to pin 27 on the instrument cluster as the sensor speed signal in. Pin 7 is the speed signal out.
Now am I correct in assuming that the only reason we have a speed signal coming OUT of the instrument harness is for the spoiler /or radio?
Can anyone tell me where this wire goes after leaving the instrument cluster? My theory is that it goes to the fuseboard and then to the spoiler control module with a wire splitting off to the radio. Can anyone confirm this ?
If this is the case, can anyone tell me whereabouts on the fusepanel I should be looking for it and any clue as to the colour etc?
Cheers
IIRC blue/white wire from gearbox VSS to a connector block on the top right of fuse board. From here it branches off to the speedo, radio and spoiler module behind dash.
Hope this helps
