chrishill 0 Posted December 4, 2003 After getting my new exhaust I had a problem with the engine vibrating under hard acceleration in low gears and the downpipes (correct term?) from the manifold hitting some part of the steering/suspension (i think). I took it back to the place i got the exhaust from and they reshaped it as much as they could, which reduced the problem massivly, but i still get vibration when i boot it in 1st. I was wondering if a new, uprated engine mount would fit the problem? as i understand it they can pretty much eliminate engine movement. Any recomendations and ideas on prices? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted December 4, 2003 OEM engine mounts don't usually allow the engine to move far enough to foul other bits of the engine bay... You might just need NEW mounts, whatever type they may be. Quote Share this post Link to post Share on other sites
aposegil 0 Posted December 4, 2003 get a engine mount from a mkII gold diesel 1.6 fits straigh in very cheap and alot stronger than original mount Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted December 10, 2003 hi chis i have the exact same problem .have moded car inc stainless exhaust and had rattles ect. much time spent adjusting exhaust usual back axel knocking.now allmost there. just need to stop downpipe hitting steering rack , as yourself.new front mount looks like the answer.now do we need expensive special mounts or like alex says use one for a golf mk2 1.6 diesel. would like to know what others are using :? cheers all :? Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted December 10, 2003 im using a turn2 front mount Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted December 10, 2003 dazz how much and were to get :D Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted December 10, 2003 got it from TURN2USA worked out at about £35 Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted December 10, 2003 does it vibrate more than normal and has it done the job. Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted December 10, 2003 doesnt vibrate at all and the engine hardly moves now Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted December 10, 2003 tried that link but cant acsses g60 mounts. cheers thou will try and get one soon. Quote Share this post Link to post Share on other sites
