daviestd
PROBLEM WITH POWER LOSS
My 95 carrado 16v sometimes hesitates before opening her up,definite loss of power. I have done a full service, only problem i can see is the exhaust needs changing although i have filled holes with exhaust cement. Having stainless steel exhaust fitted in 2 weeks. :shrug:
Exhaust cement (if it's the stuff I think you mean) isn't really meant for filling holes, it's meant for the tiny airgaps between two sections when you slot them together.
hesitation sounds like an ignition problem though, how are your plugs / leads / dizzy cap / rotor arm?
Everything changed,leads,dist cap, plugs,filters,etc...Starts brill only sometimes when you put foot down starts to loose power then goes like a bomb.
