tom31976 0 Posted July 26, 2008 I have a loose grey/white wire on in the engine bay of my 16v corrado, where does it connect to? If i connect this wire to an earth it turns on the rad fan. It is located to the left hand side of the engine bay. Any ideas? Quote Share this post Link to post Share on other sites
boost monkey 0 Posted July 26, 2008 it's the rad fan run on, it should be connected to a sensor on the bottom left corner of the rocker cover. There's a thread on this somewhere, I just can't find it at the mo. Quote Share this post Link to post Share on other sites
tom31976 0 Posted August 2, 2008 Thanks for your help, can't see any sensors though. Any help gratefully recieved. Quote Share this post Link to post Share on other sites
swiftkid 1 Posted August 4, 2008 yea i have the very same wire. its got a spade connector (mine HAD a spade connector). I dont have the sensor either but it looks like one of the sensors on the right hand side of the engine as i recall. I believe it is for keeping the fan on after the engine is turned off to give it some cooling rather than just cutting out when you take the key out. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted August 4, 2008 Found the thread for you guys: rad overrun wiring :salute: Quote Share this post Link to post Share on other sites
