a98pmalcolm
One Step Closer To Sorting Ignition
Problem :im sure weve herd this problem befor in the summer the ignition starts to slack in a corrado, but not only 2 years ago i had the barrol and switch done and now the car wont turn over, the car get unimmobilised the dash lights come up, the fuel pump turns on but i turn the key all the way to start the engine over and nothing, maybe once over the space for trying 70 times it fires up but it just sounds like there is nothing goin to the starter motor! Anything i can do to sort it out myself?
Ok in the heat its worse! but i found out today when im turning the key to the 2nd position and wriggling the key the engine ticks over and starts? what need replacing?
Thanks Again
Paul
Hi
Apparently GSF ignition switches dont last long.
Get a VAG switch and do not have heavy keys on the key ring.
