stevw1 0 Posted August 5, 2008 Hello ALL, 1995 (M) VR6 :help: After loosing clutch pedal pressure & being unable to select any gear,i was advised that the problem was the clutch master.So after sourcing one(from :hitler: )£150.00 :shock: it was fitted.NO CHANGE! advised that it was a faulty part,so it was returned.None left in :hitler: but they have one in Holland. That arrived and was fitted,no problem selects all gears & good pressure.Until you try to drive it.Once the engine is running and you engage gear,release the clutch it makes a herendous noise and forces the clutch pedal back,as though the fluid is coming upthe pedal,but really strong. What the :censored: :censored: :censored: is going on :shrug: :shrug: Simple problem,expensive remedy :mad2: PLEASE HELP ME RESOLVE,HAS ANYONE HAD THIS ????? Steve :bad-words: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 5, 2008 £150!! - they are about half that from VW Did the slave not get changed too? it should have done really as a faulty master would have put more strain on this. If you've been very unlucky you may have bent the clutch fork from driving with a dodgy pedal but I would look at the slave first Quote Share this post Link to post Share on other sites
stevw1 0 Posted August 5, 2008 £150!! - they are about half that from VW Did the slave not get changed too? it should have done really as a faulty master would have put more strain on this. If you've been very unlucky you may have bent the clutch fork from driving with a dodgy pedal but I would look at the slave first VW did not have one to match mine? Steve......... Quote Share this post Link to post Share on other sites
stevw1 0 Posted August 6, 2008 ALL FIXED NOW :clap: turned out to be a bearing in the gearbox that had disintegrated :shock: :shock: £200 for labour- subframe off,gearbox out etc,etc.... Steve :D Quote Share this post Link to post Share on other sites
