paulw12
18 16v not much power
litle power at low revs revs take time to drop dury gear change any ideas its my first corrado so dont really no my way around them :brickwall:
Welcome to the forum. :wave:
Try checking for vacuum leaks or splits in your air pipes to the throttle body, the plastics can crack and the rubbers split too.
Cleaning the ISV may help too.
If in doubt try using the Search function, most problems have been encountered before somewhere. 8)
Aye! Slowly dropping revs can also be caused by a duff overrun-cutoff valve. It's a grey cylinder behind the airbox that has rubber pipe and an electrical connection.
