jinks
Changing gear ratios
Is it possible to modify the ratios in the gearbox on a VR6 to increase low down torque? And would it be more cost effective and generally effective than a Schrick manifold? Would like to increase low down power without any visible mods.
Cheers,
Simon
Sure is, you need to use a 3.68 final drive which can be sourced from a g60 box. Another option is to swap the bell housing over to a MKIII GTI 16v box. I plan on doing this to mine when funds alow 8)
