Adz The Rat
VR Sensor Problem??
Right had a problem with the car this weekend.
Set off to the lakes yesterday, in the 4th lane of the M6 just before where it joins M55 and suddenly lost all power.
Managed to get it across all 4 lanes onto the shoulder safely, tried starting it and it turned over fine but just wouldnt start.
Exactly same symptoms and last time when the crank sensor failed (3 months ago)
So rang AA and they said same thing, seems like crank sensor again.
So towed it to Em's and we went lakes in the Golf.
Came back to the VR today, tried starting it and battery was completely flat, couldnt even open door with remote. That is strange as it has never ever had any battery problems.
So put jumpleads on and it started first time.
So what the f*ck is going on??
This could also be anything that cuts a critical power feed - fuel pump relay (probably kangaroo on cut out), ECU relay, or ignition switch.
pb
Got a piggy-back ECU? Anything else that might get in the way of the crank sensor signal to the ECU?
Otherwise go with the suggestions above..
