horney
Trottle cable question.
Hi Folks,
My throttle cable decided to come off my peddle today which was slightly annoying! My question is how should it fit the peddle arm? Mine seems to just poke through, surely it should have a split pin on the end or something?
Nick
There should be a little rubber/foam bushing that sits in round hole at the end of the pedal. They get worn with age and can let the cable fall out though. 55p to replace from GSF
It does have that, it just seems a bit shonkly. I guess the fact the cable's always under tension helsp.
My bush is quite worn (ooh er!) so I'll pick one up tomorrow.
Cheers for that :-)
Nick
