vr6tbo 0 Posted September 10, 2008 hi i'm having problems with my 95 vr. it seems i always need to crank the key twice before the car will start. on first turn it gets half way there then cuts out, then on the second turn it takes a while then finally comes to life. does this sound familiar to anyone? any ideas whats causing this? would apreciate any help. thanks mihir Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted September 10, 2008 Could be the oft' lamented dodgy ignition switch. Quote Share this post Link to post Share on other sites
carter711 0 Posted September 10, 2008 I have got a similar problem on my VR except it's temperemental. Most days it's absolutely fine but sometimes when i turn the key first time it doesn't start so i leave it for a second, try again and it starts as usual. I don't know what the problem is. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted September 10, 2008 Yup ignition switch. Worth changing if not sure anyway as theyre cheap to buy and easy to fit - just awkward. Quote Share this post Link to post Share on other sites
speedysmartypants 0 Posted September 10, 2008 i have the same prob on my mini at the mo. ignition switch. Quote Share this post Link to post Share on other sites
vr6tbo 0 Posted September 10, 2008 thanks guys will give it a go any idea where i can one from? have tried euro and gsf car parts with no luck. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted September 11, 2008 Get a genuine VAG one, the ones from GSF are rubbish quality. I had to change mine twice in one year after fitting a GSF one Quote Share this post Link to post Share on other sites
VR-OOM 0 Posted September 11, 2008 OK Stupid question of the day: If you change the ignition switch does that mean a new ignition key? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted September 11, 2008 OK Stupid question of the day: If you change the ignition switch does that mean a new ignition key? No. If you changed the barrell, yes. But not the ignition switch. From what i understand when you put the key in the barrell only the tip of the key goes into the ig switch to turn it. Quote Share this post Link to post Share on other sites
VR-OOM 0 Posted September 11, 2008 Cool, thick moment over now. Intermitantly my VR will turn over and fire then cut straight out, it will do this until I catch the revs with the throttle but if I put my foot on the throttle whilst turning her over she still stalls, have to let her fire then catch the revs? :scratch: James Quote Share this post Link to post Share on other sites
vr6tbo 0 Posted September 11, 2008 ok thanks guys got new switch, have had a look at where it goes, do i have to disconnect anything before i take it out? (apart from the plug that goes into it) mihir Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted September 12, 2008 nah thats it just the one plug. Oh and the little screw but as i said, bend a small srew driver to get to the screw, which means laying upside down so you can see the screw :lol:. But if like me you tried that and had no luck i just smashed the old one out and new one in (without replacing the screw) and then cable tied it in place. Good luck. Quote Share this post Link to post Share on other sites
vr6tbo 0 Posted September 12, 2008 sorted!! thanks for your help critical :notworthy: . used a bent screwdriver to reach the screw tapped it couple of times and it just fell out along with the switch?! like you said couldn't be bothered to put it back in so just put a cable tie around it and way presto! no more issuses. theres nothing worse than getting into a phat ride and then looking like a complete twat trying to get it going! :mad2: Quote Share this post Link to post Share on other sites
mattkh 0 Posted September 12, 2008 sorted!! HI Well done. Thanks for letting us know. please put up a photo of the screw driver you used next to a measuring tape. Cheers. Quote Share this post Link to post Share on other sites
VR-OOM 0 Posted September 12, 2008 Glad to hear you got it sorted, looks like I'm going down to my local stealership tomorrow to get one. Fingers crossed it works for me! James Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted September 12, 2008 Yeah a cable tie is always a good idea cos you know itll need replacing again in the future. The watchmaker screwdrivers sets you can buy. Quote Share this post Link to post Share on other sites
vr6tbo 0 Posted September 13, 2008 i think i got lucky with mine cos like i said i just jigged the screw a bit and the whole thing jst fell out. obviously the person who put it in didn't fasten properly cos i it was already loose. have to say it does start first time now but it cranks for a good few seconds before it comes to life, is this normal? its also easier if you unclip all the wires to give you space to get your hand in there. good luck with yours james (you are by the way going to get a creak in your neck after this though) :wink: Quote Share this post Link to post Share on other sites
