corrado g
How do I fit an ABS pedal sensor?
As above really, I know it fits on to the servo under the master cylinder but cant see any screws or a way of removing it. Also when I remove it, would brake fluid go everywhere? Would the brake system need a rebleed? Its the first time I have attempted this hence the maybe daft questions. Many thanks :)
Get a mirror on a flexible stick thing....
There is a circlip that needs releasing, you'll also need to release the vacumm pressure(?) in the servo by pumping the pedal a few times with the engine off, doesn't touch the fluid system so it's a straight swap really - just awkward to get to!
