LukeManic 0 Posted September 28, 2008 hi guys, I'm have a really annoying problem, of seems my dash is a bit loose which is causing it to squeak, it's got to the point where I'm not enjoying the drive because of it. It seems the car doesn't have it's orginal windscreen which might be a cause. If it grab the dash with two hands just above the clocks and shake it a bit I can feel a bit of give between it and the windscreen/body, is this normal? I'm basically after any advice/solution, is there a way to tighten the dash to stop this slight movement? Any help or guidance is much appriciated! Quote Share this post Link to post Share on other sites
waynos 0 Posted September 28, 2008 hi mate , the dash has two threaded ends that go through the bulkhead. On the other side nuts are screwed on to keep it tight. Its a bit fiddly to get to but if you look at the scuttle panel ( its in three pieces) look at the joins.if you put your hand directly below and reach back you should be able to feel the threaded part of the dash sticking out. Also check the two bolts either side of the dash are tight and the cheeky one hidden behind the centre console Quote Share this post Link to post Share on other sites
