blown the case
93 Corrado vr6...No Spark
Hi there, still battling with trying to start my corrado, after buying car as a non runner & discovering it had no ecu !!! :( , I have tried various things to no avail, Have bought a replacement ecu, fitted that, tried the ignition coil etc, to no avail. Its now with a veedub specialist who state it could be the distributor ? however in addition the speed sensor / crank position sensor is showing as dud, however am informed they usually read faulty when plugged up to the diagnostics ???? Any Ideas ?????
ACCORDINGLY...................
WANTED ...... a distributor for 1993 regd Vr6 Corrado (not coil pack engine), I believe its an ABV engine, can anyone help ? :D
Cheers in anticiaption
Not familiar with dizzy'd VR's as mine's a coilpack motor, but a few general checks for a dizzy engine.
1. Pull king lead off distributer and hold it to metallic part of engine. Get someone to crank the engine and see if there's a spark (hold it with something insulated so you don't get a belt)
2. Bugger ... I don't suppose they've got points inside the dizzy have they?
other stuff.
3. Are the fuel injectors operating?
4. are all necessary relays in place?
Crank sensor will report an error if engine not running although it could be faulty. Mine failed and stopped the spark and fuel so still could be an issue. Check it's plugged into the right connection though, I remember someone had an issue with a none running motor and two sensor connections had been reversed.
Where abouts are you? Perhaps someone near you would be willing to cast a 2nd pair of eyes at the problem.
Hi there, still battling with trying to start my corrado, after buying car as a non runner & discovering it had no ecu !!! Any Ideas ?????
Hi
Put up a picture of the fusebox showing the relays.
not much of a specialist are they..?,as said above check the relaysetc ,see if they are missing etc,and you could check to see of the ECU has its main live.
what ECU did you get? coilpack or dizzy?
as for fault codes...well corrados are dumb,and degrading sensors will not show up,the crank sensor will show up as faulty if cranked over for sometime,thats normal.
if the hall sensor was faulty in the distributer it would still start but be low on power as the crank sensor is its main referance point,without that you will get no spark etc.
were are you located?
