MFP
Ignition/Starting Problem
Hello All,
Hoping somebody out there can help me. Sometimes when I start my Corrado VR6 the engine starts fine then cuts out straight away. I think it is a problem with the immoboliser and or ignition key, it is an intermittent fault and if I take the key away and apply heat to it the car then starts fine and doesn't cut out. Can the key be repaired or reset in some way, or do I need a new one? . It is a most frustrating and embarrasing problem, I found myself sat in Sainsburys petrol station forecourt while I tried to start the car the other day until I finally got it to go after 5 minutes or so. Any help would be much appreciated.
Thank's
Matt :scratch:
