TITAN 0 Posted October 22, 2008 GUYS A MY CORRARD G60 keep cutting out then firing back up iv noticed that when I removed the fuel cap am getting pressure so am Thinking the fuel tank not breathing so vac - pressure building up causing Temp fuel stoppage or could I be very wrong also iv messed around with the inj--relay At the same time see if that working can anyone. cheers Quote Share this post Link to post Share on other sites
TITAN 0 Posted October 23, 2008 ANY1 PLEASE HELLLPPPPPP IT :salute: :( Quote Share this post Link to post Share on other sites
boost monkey 0 Posted October 23, 2008 write a list of the symptoms and what you have done so far. You might want to put the injection relay back to it's normal operating position as if you've been playing with it then it might hinder the troubleshooting process. Quote Share this post Link to post Share on other sites
TITAN 0 Posted October 23, 2008 OK every now an then as ma driving the engine cut out like there is no fuel then cut back in the other night engine cut i pulled over was turning over not starting pull of fuel pipe this was pumping fuel through messed with the inj-relay this was clicking but still woould not start left it for a bit about 7 mins restart fired up got out my house cut out next morning still would not start recheck fuel was pumping through and it was pull the relay out opened it up checked for any heat damaged was ok no smell of burning refited but still not working messed about with wiring loom then it startted not sure why and now as am driving still cuts out but strait back in it can not be a blocked fiter? i just dont get it arrrrrr i just can not trust using the car !!!! Quote Share this post Link to post Share on other sites
vw domo 0 Posted October 23, 2008 you say that you fiddled with the wiring loom and it started again? so have you checked all the live wires for connection faults or shorts? i know i have alot of spliced wires and when mine kept cutting out i had to go over all the crimped connections. sorted now......on to the next fault :gag: Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted October 23, 2008 Sounds like a short somewhere. Good luck, viewing it in the dark may help you see any little sparkage. On a lighter note.....Some fullstops may help us deciper your posts as well :wink: :lol: Quote Share this post Link to post Share on other sites
TITAN 0 Posted October 24, 2008 SPELLING NEVER BEEN STRONG WITH ME THANKS FOR THE TIP THOUGHT FULL STOP! ) Quote Share this post Link to post Share on other sites
