davidwort 0 Posted December 8, 2014 I think the washer should be against the spring, can't find a close enough photo of mine at the moment, I think the polo column I had came with an all in one spline adapter and top collar which may be the difference, looks like a pressed steel round collar thing on yours. Quote Share this post Link to post Share on other sites
Langsam 10 Posted April 26, 2015 I'm about to do this conversion myself. I've removed the corrado steering column and Ive found the correct used polo column. I take it from your write up davidwort the only brand new parts I need is a corrado ignition switch, a corrado steering lock and sheer bolts? Everything else should come with both the columns? Quote Share this post Link to post Share on other sites
dragon green 4 Posted April 26, 2015 You'll need the fixed column shrouds Quote Share this post Link to post Share on other sites
Langsam 10 Posted April 26, 2015 Thanks I'll get one ordered and cheers for the right up Quote Share this post Link to post Share on other sites
