AB
dizzy 2 coilpack vr
hi i am looking to replace my coilpack vr engine and i have found one thats a dizzy cap engine. can i just remove the distributor and the end plate and replace with mine so i can mount the coilpack and cam sensor? or are there other changes?
thanks
adam
will i need to change either of the cams??? one for the sensor and one cos of the dizzy???
thanks
adam
its as easy as that mate,you can use the hole cam from the dizzy or just unbolt the pickup plate at the end and rbolt it to your cam etc
