Batty 0 Posted November 3, 2008 The 'rado seems to be holding onto its revs alittle too much at gearchange, taking a while longer than im used to to drop back down. its had a cambelt and the timing is right, so should i be looking @ TPS? i'm new to k-jets so after any pointers. Thanks Matt Quote Share this post Link to post Share on other sites
Batty 0 Posted November 3, 2008 also my leccy mirrors don't work (all fuses correct) and the spoiler only raises @ speed, not on the button (opposite prob to the norm?) any ideas? again thanks in advance Quote Share this post Link to post Share on other sites
horney 0 Posted November 3, 2008 Revs: Mine does this sometimes but sorts itself out after a blast. Check all your vac pipes, does it idle right at 900rpm? Spoiler: Most likely problem is the actual switch in the dash. Nick Quote Share this post Link to post Share on other sites
Batty 0 Posted November 3, 2008 Revs: Mine does this sometimes but sorts itself out after a blast. Check all your vac pipes, does it idle right at 900rpm? Spoiler: Most likely problem is the actual switch in the dash. Nick yup the car idles like honey. no floating up or down.. perhaps an ECU reset would be worthwhile? cheers, that another switch thats bust! is GSF car parts best for switches etc? Quote Share this post Link to post Share on other sites
horney 0 Posted November 3, 2008 I don't think you can get the switch from anywhere other than people breaking Rados. Nick Quote Share this post Link to post Share on other sites
Batty 0 Posted November 3, 2008 I don't think you can get the switch from anywhere other than people breaking Rados. Nick ah. ok, thanks, better start looking at breaking 'rados then :) Quote Share this post Link to post Share on other sites
DanVW 0 Posted November 3, 2008 The throttle problem will be a sticky throttle cable, get a new one from VW :-) as for the mirros problem it will be the switch in the door, I thought there was a guide on how to fix these but I couldnt see it in the Knowledge Base Wiki, obviously I havent got round to writting it up yet lol Be very carefull when you take the switch apart as there are a few very small bits that can and will go flying off never to be seen again if your not carefull! Do it indoors over a bit of white paper! and once you have it apart, clean the copper swicth connections with a bit of emery cloth or abrasive block they will be manky and green because of at least 15 years of water ingress due to the switch's location and the fact it gets covered in water if you open the window after its been raining! :-( Dan Quote Share this post Link to post Share on other sites
Batty 0 Posted November 3, 2008 The throttle problem will be a sticky throttle cable, get a new one from VW :-) as for the mirros problem it will be the switch in the door, I thought there was a guide on how to fix these but I couldnt see it in the Knowledge Base Wiki, obviously I havent got round to writting it up yet lol Be very carefull when you take the switch apart as there are a few very small bits that can and will go flying off never to be seen again if your not carefull! Do it indoors over a bit of white paper! and once you have it apart, clean the copper swicth connections with a bit of emery cloth or abrasive block they will be manky and green because of at least 15 years of water ingress due to the switch's location and the fact it gets covered in water if you open the window after its been raining! :-( Dan Fab. thanks very much :salute: Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted November 3, 2008 Hi, Link to article in the knowledge base: http://the-corrado.net/wiki/index.php/E ... ror_repair Ian :D Quote Share this post Link to post Share on other sites
DanVW 0 Posted November 4, 2008 Link to article in the knowledge base: http://the-corrado.net/wiki/index.php/E ... ror_repair :lol: nice one Ian.... I obviously looked really hard... :scratch: Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted November 4, 2008 Later mirror switches look like this inside......2.8l 24v Climatronic system.pdfCorrado mirror Sw. change (1) (Large).jpg[/attachment:2yxvzqht]Corrado mirror Sw. change (3) (Large).jpg[/attachment:2yxvzqht] Quote Share this post Link to post Share on other sites
