woody
NON Starting some of the time!!!!!!
Hope someone can help me as this problem is really starting to pee me off
Its a 95 VR6
Put key in turn to start the car, Car turns over but will not fire. All I get is a clicking relay. I put in a new relay for the fuel pump thinking that was the problem, did not help.
The thing is the car will somtimes start and sometimes it wont. If it was a bad earth would it not start all of the time.
Anybody got any ideas what else I might change
Thanks
Woody
X releif relay has been changed and the car has started for a few weeks fine.
Today wont start again same problem.
Will the Iginition switch problem fail all of the the time or can it then work ok the next day when they are failing.
Any Ideas anyone
Cheers
Woody
To make this clear, does the engine always turn over when you turn the ignition key, with it sometimes firing up and sometimes not?
Or does it sometimes turn over and sometimes not (with just a clicking sound) being heard when you turn the ignition key?
