joeshenton
Front Wheel Bearing
Hi all,
another little issue with my little vr6 - i think one of my front wheel bearings is broke - i get a squealing and a general background wheel bearing noise. I am going to get a garage to do the work i think - i'd have to get it pressed in anyway i guess? but i need the part numbers for the wheel bearings kits i need to order?
does anyone have etka or know the number i need?
Cheers.
I would get the garage to purchase it. That way you are covered if they fit it wrongly.....
Garages tend to buy cheapo parts rather than genuine VAG. And if the pattern wheel bearings I had fitted were anything to go by, he'll be getting em done again next year... definately worth getting the genuine VW items.
1H0498625 is the repair kit
£35+vat retail, £22 + vat trade from VAG and comes with all the nuts / bolts / grease to do the job
Yup same part number of the bearings i had fitted on mine..... If it's a wheel bearing get the garage to diognose which side even if you know.... VW diagnosed the wrong side on mine.... I made then do the otherside FOC.... the front strut will need to be removed to press the bearing in.
No reason you cant tell them to get a VW one. I am just thinking about this.... viewtopic.php?f=23&t=70702&st=0&sk=t&sd=a&hilit=wheel+bearing+garage
