Pondy_p 0 Posted November 16, 2008 Hi All This is my first post so thought I'd do a new thread - I have a starting problem with my C where the ignition just does nothing. I switch it on the fuel pump primes and for the immobiliser on the car I have to wait for the oil light to stop flashing. When turning the key to start absolutely nothing happens, maybe a soft whurring. On a few occasions previously when starting it did make a fast grinding noise only just conected this happening with this latest problem - I replaced the ignition switch (also charged battery, but only 1yr old) and also spotted the cable straight from the +battery terminal to the starter was virtually broken so replaced that too. Is the starter motor knackered? If so I am reluctant to try to take it out as this may lead to alignment problems - Any pointers or tips, please? :shrug: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 17, 2008 Hi there, you need to test that your getting 12V down the red/black lead to the starter solenoid when the ignition switch is turned to the crank position... If you do get 12V ish then it's either a knackered starter solenoid or a bad earth / battery etc If not then it's either an ignition switch, wiring or immobiliser fault - did you fit one of the new black switches? Quote Share this post Link to post Share on other sites
Pondy_p 0 Posted November 18, 2008 Hey thanks for the post - I checked the voltage, do get 12v (or 11.something to be precise) I'm hoping its just bad earth as need to clean the terminals up a bit - If it is the starter can you give any indication whether this is within the capabilities of a amateur corrado mechanic with Bentley manual, which warns about supporting the engine/gear box as the alginment can shift on the car. I've seen another post somewhere else about new starters being incorrect, where's the place to get one (and let a proper mechanic do the rest), I'm guessing not GSF. It was a GSF sourced black ignition switch, but I've kept the original as it showed no sign of wear- but after the palava of getting the original out I couldn't not replace it. cheers Quote Share this post Link to post Share on other sites
