Laurie_vr6 0 Posted November 19, 2008 Anyone had this before? Every time i open the car, the central locking pump in the boot carries on hissing (pumping away i assume), for a good 15 seconds before switching itself off. Could it be down to a fault on one of the locks, or could it be a fault in the pump itself? Many thanks Laurie 93 vr6 Quote Share this post Link to post Share on other sites
coolrado 0 Posted November 19, 2008 could be a leak in the pipe to one of the locks (either a split or just blown off connector) a leaky lock cylinder worn out vanes in the pump or a jammed pressure sensor mech or microswitch in the pump try disconnecting the pipe from the pump and block the outlet on the pump, then acticvate the locks if the pump cuts out straight away or after a couple of seconds like they should it points to a leak somewhere, if it still carries on going the problem is with the pump. Quote Share this post Link to post Share on other sites
KipVR 1 Posted November 19, 2008 I think you must have air in the system, it's a common problem :D Quote Share this post Link to post Share on other sites
Leonard 0 Posted November 19, 2008 I think you must have air in the system, it's a common problem :D How do you 'bleed' it? Quote Share this post Link to post Share on other sites
coolrado 0 Posted November 19, 2008 I think you must have air in the system, it's a common problem :D :scratch: It's meant to have air in the system, they are air pressure/vacuum activated Quote Share this post Link to post Share on other sites
Leonard 0 Posted November 19, 2008 I think you must have air in the system, it's a common problem :D :scratch: It's meant to have air in the system, they are air pressure/vacuum activated Thats what I thought, help brain hurts :confused4: Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted November 19, 2008 I think you must have air in the system, it's a common problem :D How do you 'bleed' it? Cut it with a knife? :lol: YES It is vaccum operated! My pump's done this for last 3 years.. don't worry! Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 19, 2008 in my experience, it means one of the vacuum lines has come off either one of the door mechs or of the connector in the foam casing for the CL pump. pop the door cards off to check the door mech, peel the side carpets back to check the pump. Bish bash bosh. Quote Share this post Link to post Share on other sites
