repoman
g60 over fueling
Hi can anyone help! I have a 92 G60 that is over fueling to the point that it filled the engine and supercharger with petrol, all the way through till it poured out of the air filter. ECU has been checked and is ok, fuel pressure regulator is ok.
Help! :confused4:
U what. It poured out of the supercharger??? WTF.... So your inlet manifold was totally full of fuel?
I guess it doesn't run then. I would not try to start it until everything is cleaned out and 100% dry.
Stuck open injectors? Have you tested the injector loom?
