Jay23Sx 0 Posted November 21, 2008 Hello Everyone, long time no type. Quick question for you .. I was under the impression that my 1.8 KR (on an H plate) didn't have a Lambda probe as it's non-cat. However I've just been reading the Bosch Gasoline Fuel-Injection System K-Jetronic Technical Instruction book (snappy title isn't it) and it would have me believe that I do. Just wondered if this is something else I should be taking into account with my idle problems. This is the extract from the Bosch manual: Open-loop control of the air-fuel ratio is not adequate for observing extremely low exhaust-gas limit values. The lambda closed-loop control system required for operation of a three-way catalytic converter necessitates the use of an electronic control unit on the K-Jetronic. The important input variable for this control unit is the signal supplied by the lambda sensor. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted November 21, 2008 the 2litre had lambda's not the KR,but it might be different in other countrys and they might have had to run a lambda,but i cant se that as the kr is mechanical injection. Quote Share this post Link to post Share on other sites
Jay23Sx 0 Posted November 21, 2008 The book seems to suggest that the metering head alone wasn't good enough to meet emission limits hence the probe. But I was also of the opinion that the KR didn't have one. I did double check the manual was definitely for the KR system (and not any variations) but as it's the generic Bosch manual perhaps some other manufacturers did have lambda probes. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 21, 2008 99.9992% sure they don't. Mine hasn't as was the case with my Mk2 16v. With regards to the head not being good enough to meet emissions, that will be for another country with stricter laws most likely. Quote Share this post Link to post Share on other sites
Jay23Sx 0 Posted November 21, 2008 Cheers everyone .. at least my original thoughts were confirmed :) The manual was still good reading on the basic points of the KR system, especially for someone who knows nothing like me ! Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 22, 2008 that bosch book is really good, wouldn't mind picking up a copy sometime! Quote Share this post Link to post Share on other sites
