20vtvw
passat box
hi i was just wondering if i could fit a 1993 passat cable change gearbox to my corrado im running a 1.8t but was 16v if that helps??
cheers .,
sounds good i will give it a go,,i think the diff is on its way out on mine thats the main reason for a change ,,cant afford 6 speed yet!!
thanks for the help.,
checked on way home this morning, on current box (CTM code from a mk4 Passat ABF engine) 70mph=3000rpm in 5th.
cant find ratios for this box anywhere, but itll do 85mph in 3rd which is fun for coming off sliproads behind chav wagons hehehe
