MonkeyVR6 0 Posted November 29, 2008 Hi chaps, So I've replaced the front engine mount today (well, my mate did!) and now I need to replace the rear one, I'm told its more complicated. Any tips? Cheers. Quote Share this post Link to post Share on other sites
craigowl 0 Posted December 1, 2008 Make sure you get a new bolt for it - the original is "one-use-only" and they can shear quite easily on tightening to torque. I had to go to garage after bolt sheared when I was retightening. Had been replacing water pump ( you raise engine on jack after loosening mounting bolts then retighten them.) Quote Share this post Link to post Share on other sites
mattwelcer 0 Posted December 11, 2008 Remember before tightening the mounts properly up start the engine a few times to let it settle in its "natural" position. Then tighten up the mounts to the correct torque value. Quote Share this post Link to post Share on other sites
craigowl 0 Posted December 11, 2008 :thumb right: Hey! That sounds like a good one, Matt. Quote Share this post Link to post Share on other sites
MonkeyVR6 0 Posted December 14, 2008 Cheers for the tips lads, the new mount is in and all seem to be well. Next step >>> top mounts!! Quote Share this post Link to post Share on other sites
