weetos
Brake fluid reservoir removal / vac pipe installation
Hi all
I've got to replace the vacuum line from inlet manifold to brake servo and the brake fluid reservoir is in the way.
Is the reservoir just a push fit on to master cylinder?
Or is there a trick to getting vac pipe on without removing it?
G60 BTW
