phayeser
rocker cover gasket replacement
VR now back together painted, new gaskets full service all filters plugs oil etc carried out and special treat had the injectors ultra sonic cleaned.
All started up on Sunday just need a nice day now to give it a blast
Hi Ron,
Here's some questions!
The upper and lower manifold are coming off and I wanted to replace the bolts with stainless. Are they 8x30 cap bolts and do I need 17 to do upper and lower manifolds?
Second. I've had a go at polishing the manifold. I'm not too happy with the finish between the six ports. If I were to paint this, I assume I'd need a heat-proof paint?
Third. I've got hold of the gaskets for the upper and lower manifold. Are there any others I need? Is it the throttle body that connects to the upper manifold? Can't remember? Do you know if there's another gasket needed?
Cheers in advance
Jez
