ukcruisin
HELP!!! Intermediate shaft bearings
Hi all....need some advice if poss....(Have searched at length but can't pinpoint the answer)
Ive just replaced the head gasket and water pump on my 16V 2L (9A) Corrado, Its obviously getting a new timing belt and tensioner whilst in bits but when checking the freeness of rotation on the intermediate shaft pulley it feels ok most of the time but there are moments when it feels like its 'grabbing' and a little stiff. I have taken this pulley off and undone the two bolts and removed the oil seal and housing hoping I would find a bearing on the end but alas nothing. So heres my questions.....
1. How freely should this shaft turn or will it always feel slightly tight
2. Are these prone to bearing failure? Is this an engine strip down job Crank out etc?
3. Does this shaft drive the oil pump? I assume it does
Any help much appreciated!! :D Cheers guys
Thanks for the reply but I knew that it wasnt related to any timing issues I just wondered if a bearing failure was common? And if a bearing change involved having the crank out? Does anyone have of an exploded diagram of the internals of a 9A engine? :? Thanks again
it should turn freely
you dont have to touch crank but you have to drop
engine or take engine up to get the shaft out
just had to do this as bearing had failed on mine
Thats great info thanks Keith.
So if I have enough clearance, I assume I cant just pull on that shaft and expect it to slide out because it would slide out of its own accord once the engine was running. So is there something I have to undo to slide that shaft out? (Like remove the oil pump so the gears dont engage it?)
Any ideas?
Thanx
Andy
ITS HELD ONLY AT THE FRONT IT WILL DISENGAGE FROM THE PUMP OK
YOUVE GOT TO TAKE THE CAM BELT OFF TAKE THE SPROKET OF 2 BOLTS
SEAL FLANGE AND OIL SEAL THEN IT WILL SLIDE OUT BEARING IS ABOUT
£7 MINE WAS SO KNAKERED IT CAME OUT NO PROBLEM HERES HOPEING
THE ONLY THING THAT I THINK CAUSED THIS IS WRONG TENSION
ON CAMBELT ABOUT 20K MILES AGO GOOD LUCK
just a thought as the only thing the shaft drives is the oil pump
might be the pump itself worn ?
