corradog60stage4
DIY aspherical mirrors pour la corrado
original mirros look like shit
47b8da11b3127ccea87c4eda358400000016100QcOWzNuxcMR
47b8da11b3127ccea87c48f935a400000016100QcOWzNuxcMR
pry from all four corners and carefully disconnect the heated element terminals
47b8da11b3127ccea87c48b8b4d500000016100QcOWzNuxcMR
carefully separate the original glass from the heated element.
47b8da11b3127ccea87c49b5757000000015130QcOWzNuxcMR
new mirror
47b8da11b3127ccea87c4ce2b48d00000015130QcOWzNuxcMR
need to buy some goop now and stick it to this
47b8da11b3127ccea87c4da6f45100000015130QcOWzNuxcMR
got that tube of GOOP
47b8db22b3127ccea8692735e90d00000016100QcOWzNuxcMR
47b8db22b3127ccea8692681a92100000016100QcOWzNuxcMR
47b8db22b3127ccea86927efe9d700000016100QcOWzNuxcMR
47b8db22b3127ccea8692418a9b900000016100QcOWzNuxcMR
voila
47b8db25b3127ccea81713b6e21f00000016100QcOWzNuxcMR
Are all Corrado wing mirrors heated?
Where did you by the glass from dude? Are they a good fit?
I got them from Ahn Nguyen from Dub Industries.
The glass is not flat so the GOOP fills in the void and holds good.
I'm assuming aspherical is a glass with a blind spot/wide angle outer edge to it?
Would love one of these, save me running people off the road :)
So who supplies them?, I've only seen tinted or convex aftermarket lenses for the Corrado.
OEM
aftermarket
Are these "Sided" for LHD cars?
If so won't be much use for us here in the UK as the "passenger" will be our Drivers mirror
I've got these on mine, and they work fine mate. Both mirrors are slightly convex so give much better field of view than the standard ones. Takes a day to get used to it and then it's as if they've always been like that.
"Our blue wide angle mirrors help cut down on headlight glares and gives a wider view than the stock mirrors. The driver side mirror (left) is not wide angle. These mirrors do not have the heating element. But the heat pad on the old mirrors can be peeled off and reapplied to the DDI mirrors. "
:confused4:
:confused4:
Strange I could have sworn both of mine were wide angle - will have to go and check now....
:confused4:
:lol: :lol:
please post the results :) thanks!
BTW 70$ looks like lots of money ...
Yep, both curved on mine, although the drivers side is more curved than the passenger side one. I seem to remember Anh (at DDI) did some of these specifically for the British market (RHD) so perhaps mine was left over from that batch.
:confused4:
our passenger side one is useless on mine..
Anybody know if these are still available from DDI? just been on their website and couldn't find it
Just a heads up guys, The mirrors are back in stock at DDI if anyone is looking for them!
Just ordered myself a pair and I'll update in my members gallery thread when they arrive!
