dolphvr6 0 Posted December 31, 2008 was driving my vr6 earlier and car wouldnt go into gear as the pedal wouldnt go down,got her towed home,the clutch and slave cylinder hv been changed within the last 3000 miles,started taking pedal box out wen i nocticed the cylinder at the pedal so traced the feed pipe to brake resevoir,then hard pipe to slave cylinder,i opened bleed nipple and there is no pressure are they difficult to bleed as need to do this to see if its the master cylinder as its 100 quid if it is thanks Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 1, 2009 Pedal wouldn't go down?? That sounds more mechanical than hydraulic, Bleeding is easy either manually or even better with an eezibleed kit but it would have been done recently when the slave was changed... Quote Share this post Link to post Share on other sites
dolphvr6 0 Posted January 1, 2009 would go down but only til a few inches from floor the made a noise which after further investigation today seems to be coming from slave cylinder,as now wen you push pedal down it wont return Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 1, 2009 Hmmm - are you sure they replaced it?? New ones should be alloy and not painted. You can't really fit it wrong so might be something up with the clutch fork or release bearing - probably best to take it back to whoever did the clutch. Quote Share this post Link to post Share on other sites
dolphvr6 0 Posted January 1, 2009 it looks new,i would take it back but it was done in scotland and im in northern ireland Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 2, 2009 Arse! Could undo the 2 10mm bolts on the slave and remove it to have a look at and test... pedal should move freely then Quote Share this post Link to post Share on other sites
dolphvr6 0 Posted January 2, 2009 ordered a clutch kit for 75 quid gona change everthing just to be sure,thanks for your help charged owe you a beer lol Quote Share this post Link to post Share on other sites
