tribetype40 0 Posted January 15, 2009 WOW, first post for quite a while! I have finally got back around to playing with the Corrado! harrah Could anyone with access to EKTA help me out please? I need the part number for the above part. Its the sender ring that mounts on the the end of the camshaft. Cheers Doug PS also if anyone has an early 24v cam cover I need one of those.... Quote Share this post Link to post Share on other sites
tribetype40 0 Posted January 15, 2009 I aways do this! the actuall info may be handy! part number for the sender ring on a '94 VR6 corrado Quote Share this post Link to post Share on other sites
iceviolet 0 Posted January 15, 2009 CAM POSITON TRIGGER WHEEL 021 905 163 Quote Share this post Link to post Share on other sites
tribetype40 0 Posted January 15, 2009 nice one, cheers I called into the stealers on the way home tonight and they seamed to list two numbers and needed my vin (seams dealers cant go to the loo without a vin!) does anyone know what the difference is? Quote Share this post Link to post Share on other sites
iceviolet 0 Posted January 15, 2009 There is two numbers, the first number is for the distributor coupling and the secon for the CPS. It states that the CPS is for F 50-P-009 001>> and the distributor type coupling for earlier numbers. Quote Share this post Link to post Share on other sites
tribetype40 0 Posted January 15, 2009 ok I see. so all the later cars with coil packs have this later number as the other one is only distrubuter cars? You would have thought the dopey dealler would have been able to tell me that! anyway thanks for the help I will get about ordering one. Cheers Quote Share this post Link to post Share on other sites
iceviolet 0 Posted January 16, 2009 Yes it looks that way. As you say, i also find the staff at the VW parts department very un helpful at times. Quote Share this post Link to post Share on other sites
