vwgti 0 Posted January 16, 2009 Can we use the gearbox from the ABF 2.0 16V engine by just transferring the Corrado VR6 gearbox bellhousing into the ABF gbox? I understand that it has lower final drive. I do some track days and autocross and just find that the standard ratios too high for track/autocross work. Or is it easier to just transfer the final drive over? Your help on this will be appreciated. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 17, 2009 its only the bell housing that differs,but you will have to strip the box right down to do that,so in that case its the same amount of work which ever way you decide to do it. Quote Share this post Link to post Share on other sites
