Anton Sobriquet 0 Posted January 30, 2009 I'm just about to send some Mk4 brakes off to BiggRed to get them refurbed and polymer coated. I've got Golf 4Motion calipers and carriers going on the front, for a 312mm upgrade, and Golf 4 calipers going on the rear with the Eurospec 280mm rear upgrade kit. I'm a bit stuck on which rear carriers to use. I've read thro' the thread on the rear Mk 4 conversion but I'm still stuck:- Q1: Can I use Golf 4 rear carriers (which came with the calipers), or I should use the standard VR6 rear carriers with the 280mm upgrade kit? Q2: If I need to use the standard VR6 rear carriers, does anyone know which Mk3 Golf ones they correspond with, ie Girling or Lucas (so BiggRed can order some in for an exchange deal and save me having to take mine off the car in advance)? Cheers for help in advance. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 30, 2009 u use the standard VR6 caliper brackets and the 280mm conversion just spaces them out futher. Quote Share this post Link to post Share on other sites
Anton Sobriquet 0 Posted January 30, 2009 Thanks for that. I want to avoid taking my carriers off in advance of having the brake conversions done, because I need to use the car whilst BiggRed refurb and polymer coat the Mk4 stuff. Do you know which Mk3 rear caliper/carrier set corresponds with the standard Corrado VR6 ones? I just need to know whether they'd be Girling or Lucas ones. You see, BiggRed will do an exchange on rear carriers but they don't keep Corrado specific brake parts in stock for exchange and they don't currently have any Mk3 rear brakes in stock. They said they'd got an order going in for Mk2s' on Monday and they can add/amend it to include a pallet of Mk3s', but they need to know whether to order Girling or Lucas Mk3s'. I would have thought the carriers would have to be the same irrespective, but best to get it right just in case there is a difference. I suppose the simple solution would be to see which ones are fitted on the Corrado, ie Girling or Lucas, but I can't get to the car at the mo to check............ Can anyone help, please? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 30, 2009 as far as im aware all the steel type rear calipers are interchangable,from mk2,3 corrado VR6 g60 etc but i dont know what the make is bud. Quote Share this post Link to post Share on other sites
Anton Sobriquet 0 Posted January 30, 2009 So it wouldn't really matter whether they used Girling or Lucas Mk3 carriers then? Or, for that matter, whether they were Mk2 ones? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 30, 2009 yip and yip :tongue: Quote Share this post Link to post Share on other sites
Anton Sobriquet 0 Posted January 30, 2009 That makes things a lot easier. Thanks for your help, mate! Quote Share this post Link to post Share on other sites
