vw corrado storm king
ABS
Gents please help
1st Got a 1995 vw corrado storm and have been having a small problem with the rear brakes (i hope small) when i accel hard and spin the front wheel in fisrt and sometime second the rear wheels lock and wont unlock till it comes to a stand still.
2nd Seems to lack alot of power but no fault codes ????
3rd Had a few starting problems the other day too start it first thing in the morning and fires up ok but won't idle cuts out straight away
"rear wheels lock" .. huh? The back brakes are pathetic at best, so I doubt this is anything to do with the ABS. Might have a problem with the rear brake load compensator valve (the front will lift quite high during silly acceleration) but I'd be surprised...
Lacking a lot of power but no error codes .. fuel filter/pump? Is it pinking? How's the MPG?
The cuts-out-straight-away is typical of the factory immobiliser. Use the search luke .. ! ;)
