Badger
Oil for VR6?
Last time I used Synta Silver it was over £40 for the oil alone. I'd contact oilman (Opie Oils). You can stick pretty much any 10W/40 semi-synth in though. Might be worth using fully synth if you use the car on track or run it hard. There are loads of posts on this though so you might want to use the search :)
Not sure where you are getting your Silver from mate but its £16 for 5L's at my local dealer :grin:
Syntha Platinum replaces both Syntha Gold and PD diesel...
It's £15 for 5 Litres via TPS but they are also doing the gold for £12 to get rid of stocks (PD oil is a tenner!)
