Riley 0 Posted February 21, 2009 Does anyone have any info/ratio's etc for the CHA gearbox? Cheers,Neil. :) Quote Share this post Link to post Share on other sites
RedTyphoon 0 Posted February 21, 2009 http://www.gti-vr6.net/wiki/index.php?t ... 27s_ratios :wink: Quote Share this post Link to post Share on other sites
Riley 0 Posted February 21, 2009 Cheers mate 8) So it uses the correct flanges? Same size output/spline shaft? Neil. Quote Share this post Link to post Share on other sites
s1m0n 0 Posted February 22, 2009 http://www.gti-vr6.net/wiki/index.php?title=VW_transmissions%27s_ratios :wink: Not sure that's correct, I have a CHA, taken from a turbo diesel B3, my understanding is ratio's as follows: - CHA 1st - 3.78, 2nd - 2.12, 3rd - 1.36, 4th - 1.09, 5th - 0.72, FD - 3.94 As for fitting, yea any 4cyl C that has an 02A - No problem Cheers Simon Quote Share this post Link to post Share on other sites
RedTyphoon 0 Posted February 22, 2009 http://www.techtonicstuning.com/trannyratios.asp :shrug: Quote Share this post Link to post Share on other sites
s1m0n 0 Posted February 22, 2009 http://www.techtonicstuning.com/trannyratios.asp :shrug: Just been on VAG CAT and checked the teeth: - 1st - 34/9 = 3.77 2nd - 36/17 = 2.12 3rd - 34/25 = 1.36 4th - 33/36 = 0.92 5th - 33/46 = 0.72 FD - 71/18 = 3.94 And it's listed for the B3 so looks like Techtonics have it right and I was wrong about 4th! Cheers Simon Quote Share this post Link to post Share on other sites
Riley 0 Posted February 22, 2009 Cheers lads, now the question...Anyone know what speeds this box would give in each gear? Im trying to compare it to the CTN code box. Cheers for the help. Neil. Quote Share this post Link to post Share on other sites
s1m0n 0 Posted February 23, 2009 What tyres are you running Quote Share this post Link to post Share on other sites
Riley 0 Posted February 23, 2009 215/45/16 mate :D Quote Share this post Link to post Share on other sites
s1m0n 0 Posted February 23, 2009 There are several ways to do it, I do it this way, tyre diameter*pie*revs/1056*gear*FD Your 215/45/16 comes back as having a 23.61 diameter, so, 23.61*3.1416*1000/1056*3.77*3.94 will give you the speed in first gear at 1000 rpm (I make it 4.72) I usually use a spreadsheet so I can get a nice little graph to overlay onto my dyno plot Cheers Simon Quote Share this post Link to post Share on other sites
