mort1414
central locking question
my central locking doesnt open my boot was this an option or is mine just broke as im sure my last vr had the boot on its central locking
tried the search could nt find anything
cheers
hi mate I've had the rod from the solanoid to the lock get a little corroded just sticky really so the compressor hasn't got enuf gut to push it! Take of the panel on the tail gate and you will see re rod just check it moves freely if it does then start checking leaks an then finally take off the airline suck and blow on the solinoid make sure it works lol finally check if your getting air pressure through the pipe when you lock it :) hope it helps
