jamie_h_1979
G60 Hoses
I found hose part numbers if it helps ya mate,
throttle body to upper ic tube: pressure hose / F >> 50-M-000 660 upper / (16) 535145838
upper ic tube to intercooler: pressure pipe / F 50-M-000 661>> lower / 12 535145832A
silencer box/rsr outlet to lower intercooler pipe: pressure hose upper / 13 N 0245223
lower ic tube to intercooler: pressure pipe / F >> 50-K-005 000* lower / 11 535145845A
alternate for 535 145 845A: pressure pipe / F 50-K-005 001>>*50-M-000 660 lower / (11) 535145845B
you may have to register here but here is the link, hope it works out CLICK, check the link you will have to register to see the Web page.
On a set of Samco Sport IC hoses:
Round ends:
OD 2 3/4"
ID 2 5/16"
Oval end:
OD 3 13/16" x 1 15/16"
ID 3 3/8" x 1 1/2"
th_SamcoICHoses001.jpgth_SamcoICHoses002.jpgth_SamcoICHoses003.jpgth_SamcoICHoses004.jpg
