paul20v
5 stud rear to 4 stud
hi
strange i know but will i have any issues putting a 16v/g60 rear axle on a vr6 ,
why you ask i want 9x16 on the rear and i will surely have less arch mods with a 4 stud axle ,
or is this not a worth while mod as i dont know how much difference there actually is
any help or ridicule welcome :D
i thought is was just the discs to do the studs as there as one hub and disc ,
is there any axle mount issues
and what the width difference in axles
Paul
The axel mount the same to the body,the stub axels are the same bar the early i think had no abs sensor holders,but it does not matter as you can just fit over your stuff to the narrow aexl.
width? i dont know mate.
But its something like 10mm either side wider on the VR
Thanks for the info mate ,
10mm per side is well worth the mod i think as that will make the et from 15 to 25 which is great
thanks for the info
now all i have todo is hunt for a g60 or 16v axle :)
so it looks like i can use the rear beam off a mk2 golf as well but i will have to use the chassis mount plates to as the bushes are smaller .
I'm using a golf beam, no problems here.
was it a straight swap , sorry to keep on i dont want to get the wrong axle and if i have a mk2 golf option too theres more chance of me finding one
i might hi jack my mums E reg Golf gti axle i will do here a swap :D
